Please help me get better residuals
Old   November 9, 2024, 17:03
Question Please help me get better residuals
Adam
Robbebatte is on a distinguished road
I am currently attempting to run some CFD simulations for the rear wing of a formula student car, however i am having some issues getting the residuals to converge properly, specifically the Tdr residual.
I am using steady state solver and segregated flow, with K-epsilon turbulence. I am quite certain that my setup should be steady state with no time dependent variables. Also i have 5 prism layers, with a total prism layer thickness of 0.008m.
I have a very fine mesh so i don't believe my issue lies here. Also i am using a velocity inlet with 20 m/s and a pressure outlet at 0 Pa located 25 meters back from the inlet.
I have attached a copy of the residuals i have received. This is the second running of the sim so i know that the Tdr residual doesn't converge more with further iterations.
I would greatly appreciate any help/ideas on how i can improve the residuals.
Robbebatte is offline   Reply With Quote
Old   November 15, 2024, 11:53
Smile Adjust normalizing factors
Arvind Jay
arvindpj is on a distinguished road
I don’t see any major issues, as these are scaled residuals. For Tdr convergence, here are a few suggestions:
  1. Skip the first 50 iterations since turbulence is still developing early on.
  2. Adjust normalizing factors in STAR-CCM+; you can either set them manually or let STAR-CCM+ handle them automatically, which may stabilize residuals.
  3. Lower under-relaxation factors for momentum and turbulence variables.
  4. Refine mesh in high-gradient areas or switch to a coupled solver if needed.
These steps should help improve Tdr residual convergence. Let me know if you need more assistance! More info in this video series.
arvindpj is offline   Reply With Quote
Old   November 20, 2024, 15:00
SESP is on a distinguished road
I agree, the results don't look too bad. I would not rely on those too much but rather on the quantities that you are interested in.
Add some monitor points and observe mass flow rates, pressure drop, max + avg quantities, etc. Use those to judge your convergence. Residuals are nice for quick info, but I would always analyze the relevant quantities.
SESP is offline   Reply With Quote
aerodynamics, cfd, formula student, residuals, turbulent dissipation
Interpreting residuals, in ramped pressure jet NotOsborneReynolds Main CFD Forum 1 January 11, 2022 12:13
Cannot find functionObject file residuals vava10 OpenFOAM Pre-Processing 2 November 14, 2020 13:21
motorBike Residuals for SST k-omega... and mine JR22 OpenFOAM Running, Solving & CFD 6 August 1, 2013 10:08
judging convergence through residuals MachZero Main CFD Forum 7 December 25, 2012 13:18
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 06:45
