Propeller simulation boundary conditions, steady state
Old   October 29, 2024, 18:36
Default Propeller simulation boundary conditions, steady state
Kevin Gnanaraj
keg504 is on a distinguished road
Hi all,
I'm trying to run steady state simulations of a propeller in steady state with an oncoming wind of 17 m/s. I have two regions/domains, a rotating one (I setup a rotating reference frame under tools with the intended rotation rate) and a stationary domain, with symmetry for a 2 bladed propeller. I have ~5.6 million cells with a polyhedral mesh, prism on the blade and the hub. The hub is a slip wall, while the blade is a no-slip wall.
The blade is subtracted from the rotating region after a surface wrap (the original STL is not watertight). I'm getting strange results for the simulation, and I'm very confused about the boundary conditions. I have a velocity inlet with 17 m/s, set component-wise. The outlet is an outlet condition, and the opening to the air is set as a pressure outlet. I have an example case that converges well (all residuals in order of 1e-06) that I'm trying to not replicate, but use as a basis for my analysis, and it sets the opening to a freestream boundary condition. That causes my x-momentum residuals not to converge at all, and the expected thrust is 2/5 of what is expected from BEMT.
What are the correct boundary conditions? I have done a static thrust analysis of propellers in CFX, and that had an opening boundary condition, but now I get reversed flow that the opening boundary condition solved well.
I have attached velocity and residual plots. I will send a mesh plot later after I get more iterations of the simulation and stop it.
Edit: Here is the mesh plot
keg504 is offline   Reply With Quote
boundaries, propeller convergence, propeller thrust
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
What are the best settings for a channel flow simulation? Ashkan Kashani CFX 3 October 13, 2022 22:36
Transient simulation gives worse results than steady state simulation jgross CFX 12 January 21, 2021 13:21
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
