StarCCM on Cluster with SLURM Scheduler Error |
October 1, 2024, 19:05 |
Hello all;
I just signed up for this site, so forgive me if I posted this in the wrong place. I frequently run StarCCM on a cluster that uses PBS for work and never had any problems with scheduling jobs. Now I have to run it on a cluster for academia that uses SLURM and am having some issues. I have the job being split across several nodes and it appears to check the license out, then it gives a username error (see attached). I have never seen this error before, is anyone familiar with it? My execution call within my job scheduling submission is: nohup $STARDIR/starccm+ -rsh ssh -batch $BATCHFILE -np $NCPU -machinefile $MACHINEFILE $SIMFILEPATH Where BATCHFILE NCPU MACHINEFILE and SIMFILEPATH define the java batch script, number of cores, list of nodes, and the simulation file. CFD Error.jpg |
client, error, hpc, starccm, uid |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 19:11 |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 07:25 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
