Constraint of angle in a multi-body motion sim
Old   August 29, 2024, 05:29
Lightbulb Constraint of angle in a multi-body motion sim
Tigrou is on a distinguished road
Hello everyone,
I am working on a multi-body motion case and need to apply an angular constraint between 2 bodies. However, I can only achieve this using the “one DOF rotating motion” option, which does not allow for coupling.
Is there an option to apply an angular constraint in multi-body motion without using another solid to stop the movement?
Thanks you in advance for your answers !
Tigrou is offline   Reply With Quote
dem, multi-body motion
How to define movement/deformation relative to a rigid body motion in Fluent by udf? eagle_001 Fluent UDF and Scheme Programming 6 May 17, 2022 04:41
Multi subset mesh motion hchen OpenFOAM Running, Solving & CFD 3 March 6, 2022 00:41
dynamicFvMesh - tabulated motion of a solid body + mesh morphing HendrikW OpenFOAM Pre-Processing 3 December 3, 2019 03:05
A rotating blunt body within a "box" of air at an angle? li0012in CFX 1 January 11, 2012 20:25
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
