August 22, 2024, 11:56 |
Binary Water Droplet Collision Issue
I'm currently simulating binary water droplet collisions using STAR-CCM+ with the following parameters: - Droplet Diameter: 400 microns - Water Density: 1000 kg/m³ - Water Viscosity: 0.001 Pa·s - Air Density: 1 kg/m³ - Air Viscosity: 1.8e-5 Pa·s - Surface Tension: 0.072 N/m - Relative Velocity: 1 m/s - Mean CFL Number: 0.5 - Max CFL Number: 1.0 I placed one droplet in a box that is 800 microns long with all six surfaces set as Symmetry Planes. The droplet is given a [1, 0, 0] velocity to make it hit the right surface. However, the droplet deforms significantly as it travels. Could someone please advise on what might be wrong with my simulation? I have attached some pictures for reference. Isosurface.jpg Mesh.jpg Models Used.jpg Thank you! Oscar |
August 27, 2024, 09:39 |
Rep Power: 2 |
Consider using a different boundary condition, such as no-slip walls for the surfaces that the droplet may contact. Also An 800-micron box might be too small for a 400-micron droplet, especially given the high relative velocity.
August 27, 2024, 16:02 |
Joern Beilke
Rep Power: 20 |
I did similar things in the past and it never worked with AMR. Best to use a fine cartesian mesh with all cells of the same size.
Question about water droplet impact on surfaces with different water contact angles | kdang | FLUENT | 0 | November 2, 2023 08:26 |
Vapor formation during single droplet condensation problem | Luuuca94 | Fluent Multiphase | 2 | October 4, 2021 12:58 |
Water droplet falling in humid air | koslv | FLUENT | 0 | April 19, 2018 00:06 |
Simulation of varying contact angles for a large droplet of water on a surface | cp703 | CFX | 5 | July 20, 2013 06:08 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 08:42 |
