Mario Mouzouris
Rep Power: 0 ![]() |
I am trying to model the flow through a pilot operated poppet valve with a return line leading to a lower pressure. The inlet and outlet are roughly 1" and the return line is roughly 1/8". The boundary conditions I'm using are as follows. A Stagnation Pressure inlet, a Pressure Outlet at the outlet with a Target Mass Flow option and a Pressure Outlet on the return line. I have reviewed my mesh and it appears to be of sufficient quality, however, I am running into an issue with instability of my results. Both my residuals reduce but they fluctuate randomly, so do my monitored values. If anyone could offer an idea as to what could be causing it I would appreciate it. Thank you. |
target mass flow rate, two outlets |
OpenFOAM on AWS Ubuntu EC2 Instance | mcc12 | OpenFOAM Programming & Development | 1 | October 28, 2021 13:22 |
running mapFields in parallel | mkhm | OpenFOAM Pre-Processing | 10 | September 16, 2021 13:12 |
Floating issue when running openfoam through grasshopper | Mark JIN | OpenFOAM | 1 | May 24, 2017 21:04 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 04:59 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
