Rotor Simulation Divergence Problems
Old   June 17, 2024, 09:23
Default Rotor Simulation Divergence Problems
Pedro Santos
PedroSantos is on a distinguished road
Hello guys,
For my master's thesis i need to validate a propeller with some data from another paper. Initially i did a simulation for a static test, just to see if the methodology worked. I have a rotating region with the propeller inside and i input the rotation ratio (RPMs), and then the static region and both are connected by interfaces. I followed a tutorial given by a university i did an erasmus in, and also followed some videos available online, whose methods were the same. You can see the mesh both regions in Mesh.jpg.
The static simulation worked well from what i understood, at least i had no problems. I set the timestep to match 1 degree of rotation. SST K-w turbulence model, ideal gas, segregated flow. The prism layers are built to achieve an y+ of around 1.
However i needed to validate thrust values for the propeller at 6000m of altitude, at mach 0.46, which at that altitude is about 145.9 m/s.
So i changed the Boundary values to the matching values at that altitude:
Reference Pressure around 40Kpa
Freestream speed of M 0.46 and Temp 250k
I also changed the initial conditions to match the BC.
The initial timesteps seem to be alright. But soon after the residuals skyrocket Residuals.jpg, and it appears this error Error.jpg. Some of the sims before diverging have these weird valuesDiveregence problems.jpg.
I spent more than a week doing parametric studies, changing the mesh, the time step, the initial conditions and nothing changes. I Would be really grateful for any suggestion, because i cant understand why this is happening...
PedroSantos is offline   Reply With Quote
divergence problem, rotor, starccm+
Population Balance Modeling (PBM) - Ansys Fluent chittipo FLUENT 164 November 18, 2023 12:54
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Combustion problems: solver divergence occurs when turning on high temperature patch nishant FLUENT 2 February 8, 2015 06:20
buoyantBoussinesqSimpleFoam divergence problems beretti_a OpenFOAM 2 February 8, 2010 12:13
