VOF solidification-melting with porous media - Residual amplitude keep growing |
Rep Power: 0 ![]() |
Good morning, Good afternoon, and Good evening
I'm just trying to simulate melting of paraffin wax in metal foam using VOF model with implicit unsteady in 2D. I made two regions-pure paraffin region(fluid region) and paraffin with metal foam region(porous media region) and they have simple boundary condition that every wall is adiabatic except one wall with heat flux. It seems the solving process went well, but I found out that the oscilation amplitude is keep growing and finally exploded with warning message. Actually, If I simulate only pure paraffin or only porous media regions of paraffin there was no issues. So I did everything that I know and searched every manual that I used. Here is the lists 1. Making fine and uniform mesh, and also checking the mesh mating on interface. 2. Reducing time step 3. Reducing under relaxation factor of sgregated energy fluid, because before exploding, some cell exceed limitation of temperature(5000K) These things that I have already done, was actually helpful to extend the time of stable solving but it keeps exploding.(First exploded at 100s and now 500s) Can you give me advices that I can fix? I will send you some images if you are not understand. Thank you for reading and have a good day ![]() Last edited by Cheong; June 1, 2024 at 21:56. Reason: Fixing last two senteces |
porous media, solidification & melting, vof modeling |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
