Arjav
Rep Power: 0 ![]() |
Hello All,
I have a structured multi-block volume grid file (bwb.cgns) that I'm trying to import into STAR-CCM+, which is in the .CGNS file format. The issue I'm facing is that when imported into STAR-CCM+, the boundary and the corresponding boundary conditions information is lost. All I see are the different blocks as different regions, with the whole block as a wall boundary. I've checked the boundary information within the CGNS file with standard CGNS libraries and see (bc-info.txt) the boundaries and the conditions assigned but can't get STAR-CCM+ to recognize this. I've attached the file I'm using and the BC info the CGNS library gives when using 'writebcinfo'. Has anybody faced a similar problem? |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
CGNS problematic import in Pointwise | S.Kontogiannis | Pointwise & Gridgen | 8 | April 17, 2014 07:28 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
CGNS import | Anton | FLUENT | 1 | November 23, 2002 07:58 |
