Steepening of compression waves in long pipelines |
April 6, 2024, 05:36 |
Stone
Hello, experts
I would like to ask some questions that I have encountered in this forum I am working on a problem of compression wave propagation in a long pipe. It is well known that compression waves propagating in long pipes will increase the pressure gradient due to nonlinear effects, but my model has not been able to get the desired result (CCM+) without reporting errors, and occasionally the pressure gradient will rise and fall for a certain period of time (according to the budget, this period of time has not reached the decay condition), instead of continuing nonlinear steepening. I have been distressed for a long time, and I hope the experts present here can give some advice, thank you! |
April 6, 2024, 05:40 |
Stone
I hope you can give some suggestions on turbulence model setup. If anyone else has this problem or a solution, I'd be happy to talk to you about it.
gradient,steepening, waves |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
OpenFOAM-1.5-dev svn revision 1438: libOpenFOAM does not compile in SP | 4xF | OpenFOAM Bugs | 3 | October 16, 2009 05:35 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
