Turbine in Star CCM+
Old   April 5, 2024, 04:17
Post Turbine in Star CCM+
Daniel Wirch
Seroduso is on a distinguished road
I'm a student and my thesis topic includes a CFD simulation of a radial turbine with Star CCM+. I am running a three dimensional implicit unsteady simulation with k-omega turbulence, coupled flow and ideal gas. The turbine should have a specific rotation rate as the goal, which i put into the simulation as a rigid body motion for the impeller region. How do I verfiy the design? Is it via the pressure drop between input and ouput? Is there another way?
Seroduso is offline   Reply With Quote
Old   April 5, 2024, 19:28
Peresvet
Peresvet is on a distinguished road
Good day. If you have a powerful PC, then it is better to use an overset grid. In my example, you need to solve the inverse problem, and use pressure filling instead of air speed. Delov then!!!
https://youtu.be/xDyWPHa41KE
Peresvet is offline   Reply With Quote
Old   April 9, 2024, 11:45
Daniel Wirch
Hello Peresvet,
thank you for the tip. I am going to implement the overset mesh for the impeller.
What do you mean by the inverse problem? Have a monitor of the pressure difference between input and output? And what does "delov" mean?
Old   April 9, 2024, 15:11
Peresvet
Hello Peresvet,
Hello.
Delov! A proverb in Russian means, simply, easily, without problems.
In my example, this is a wind generator turbine and it is spun by the air flow at the inlet. In your case, I assume, the turbine has already been given a rotation speed and all that remains is to determine the pressure.
To control the pressure in a given section or on the surface of a turbine, etc., you need to create a new scalar scene and select the field function in it > select the appropriate one from the list.
rigid body motion, turbine, verification
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
problem when imported geometry from 3D CAD to star ccm, TAREK GANAT STAR-CCM+ 1 May 21, 2013 23:15
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
