April 3, 2024, 15:38 |
Integrating PID into StarCCM+
I'm new to star and I'm trying to integrate PID controller into StarCCM+ to modify input parameters during simulation run. Basically, I want to start simulation for a given input condition then I feed the output for 1 timestep into my PID code modify the input again for the next timestep based on the result of PID code. The problem is I'm not sure how I can feed my PID input into StarCCM+. I did check out some research work but they don't talk about how they did it. |
star ccm+ help |
Crushed with error "mpirun noticed that process rank 3 with PID 16913 on node" | lcraul | OpenFOAM Bugs | 3 | November 17, 2023 09:32 |
PID control of valve using the immersed boundary method in foam-extend | qkrtjdrns | OpenFOAM Post-Processing | 2 | March 25, 2023 10:43 |
Treatment and visual representation of CAD in Starccm vs other meshing software | granzer | STAR-CCM+ | 1 | October 13, 2020 09:54 |
PID control of valve using the immersed boundary method in foam-extend | qkrtjdrns | OpenFOAM Running, Solving & CFD | 0 | April 3, 2020 12:00 |
PID control of valve using the immersed boundary method in foam-extend | qkrtjdrns | OpenFOAM Programming & Development | 1 | April 3, 2020 11:57 |
