Rep Power: 0 ![]() |
Very new to CFD and looking into using an active flow control blowing actuator to analyse flow separation, and lift/drag coefficients. Used a baseline NACA0012 aerofoil to get 2D simulation results, I generated a 2D mesh, using calculated values to set prism layer thickness, for a Y+ = 1 and the results were accurate when compare to current research and javafoil estimations.
I have created a CAD model of the modified aerofoil (i.e. with a slot cut into the surface to be used as an additional velocity inlet, imported into STAR CCM with no issues. Due to positive results with initial baseline mesh, I have tried to marry this mesh across to the new modified part, however, I lose the prism layers at the point at which the slot is cut into the surface. I ran a simulation anyway and the lift/drag values are way off what I was expecting (CL is 1.2 at 1Deg AoD, when I was expecting 0.1 ish). Lead me to believe the loss of prism layers are causing the spurious results. To rectify, I have tried reducing the stretch factor of the mesh, minimum thickness size, number of layers etc. and also surface mesh. I have tried using a volumetric control by pinpointing the affected area with a cylinder or a block and controlling the mesh that way, each method has failed me. Does anybody have any ideas as to how I can refine this troublesome area? Many thanks Attachments - Baseline Mesh Domain Baseline Mesh Leading Edge Close Up Modified NACA0012 Close Up Modified NACA0012 Mesh NACA0012 Modified CAD Close Up.jpg NACA0012 Modified.jpg Baseline Mesh 1.jpg Baseline Mesh.jpg |
#2 | |
Chaotic Water
Rep Power: 18 ![]() |
You can override that with Surface Control at slot surface (check Override option and set Prism Layers parameters). |
Many thanks for the quick response, I’ve managed to refine the gap as much as I can although whe I have assigned the surface control to the slot inlet with specified prism layer parameters, no prism layers are created, which I can’t understand wh
Rep Power: 16 ![]() |
If I understand correctly, you are modeling your outlet just as a surface patch. This will always result in the prism layers collapsing. I would actually model a small section of the slot in the CAD, so "into" your airfoil. By this, you would have a segment of the channel inside the airfoil resulting in the prism layers to follow the surfaces including the sharp edges.
mesh 2d, prism layer meshing, star ccm+ mesh |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 13:05 |
[snappyHexMesh] Not Able to Refine Mesh in Refinement Box | noodleluvmay | OpenFOAM Meshing & Mesh Conversion | 2 | January 27, 2020 10:55 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
