Using a laminar model to predict flow instability in a square pipe loop |
March 25, 2024, 18:13 |
Moazzam
The assignment I'm working on requires me to use a pre-existing STAR-CCM+ model to predict the temperature difference at which the flow becomes unstable. The geometry is a square pipe loop with vertical heating and cooling. I have a mass flow monitor at the cross section of the pipe. My thinking was to run the simulation with increasing temperature difference at the hot end and the cold end until I see oscillations in the mass flow reading, however, my supervisor wants me to validate that result with a time dependant simulation as well. This I have no clue how to do. Any advice on this would be amazing.
P.s. the working fluids will be air, water, lead-bismuth, and liquid lead. |
loop, stability analysis, vhvc |
Convective Heat Transfer in Laminar Flow | CFDJonas | FLUENT | 8 | April 1, 2022 16:01 |
Using a turbulent model when the flow is entirely laminar. | mwhyte | FLUENT | 1 | June 7, 2012 10:35 |
Laminar pipe flow | vahidj | FLUENT | 3 | May 11, 2012 13:27 |
Mixture model - pipe flow | Aly | FLUENT | 10 | June 21, 2010 13:50 |
First steps - laminar flow in a pipe | Maria | Phoenics | 8 | November 27, 2001 11:26 |
