Daniel
Rep Power: 2 ![]() |
I am currently trying to simulate an interaction between 2 fluids. It is a rocket engine and I have 2 separate inputs where I want two different liquids to enter separately and then visualise their interaction in the combustion chamber. I am not perticuallary interested in a break up model but just how well these mix and what their velocity will be. My Model is currently 3 parts. I have tried to simulate as one part and as 3 different parts with a new physics for each region part. They are currently connected via Interfaces but Star CCM sets these interfaces as baffles and I cant change it. Thanks for your help ![]() |
Rep Power: 16 ![]() |
If you are not interested about the liquid-liquid interaction, I would consider running them the problem as a single phase simulation and adding a passive scalar to track the two different fluids. This will be a much simpler setup, faster to run and more robust. An alternative would be a multiphase setup where you still need only one continuum but then 2 different liquids.
This, however, is complex and you need to know what to do. Multiphase simulations are a class of its own with many different options and models. |
interaction, liquid, mixing flow |
Interfaces position in Star CCM | GV77 | STAR-CCM+ | 5 | March 25, 2024 14:50 |
Star CCM Acoustics Analysis of a pipe | Hassaan595 | STAR-CCM+ | 0 | June 5, 2023 16:09 |
How to create liquid gaseous interaction in the same container? | haristrawberry | CFX | 4 | June 14, 2015 06:54 |
what is the best method to learn analysis using star ccm? | vignesh_n | STAR-CCM+ | 3 | March 3, 2015 13:16 |
Problem in PERIODIC BC in STAR CCM | mohammad | STAR-CCM+ | 7 | January 28, 2015 09:38 |
