March 6, 2024, 02:58 |
The Specified y+ Heat Transfer Coefficient
Sunfangfang
I am simulating convective heat transfer of turbine blade to get areodynamic heat from flow. I have give boundary as Adiabatic。
I post-process results, get this: 1. local heat transfer coefficient = 5000, 2.Specified Y+ Heat Transfer Coefficient = 100-500. 3. Heat Transfer Coefficient =0. Could any one explain Specified Y+ Heat Transfer Coefficient? 1. Is it proper to use Adiabatic boundary condition? 2. Is it reasonable to use Adiabatic boundary condition and Specified Y+ Heat Transfer Coefficient for my blade conductive heat transfer? 3. from my view, when i set Adiabatic boundary condition, the heat flux on wall shall be 0, and Heat Transfer Coefficient also be zero, so why is Specified Y+ Heat Transfer Coefficient and local Specified Y+ Heat Transfer Coefficient is not zero? 4. If i want to compare my result with my experiment, in which i get h by Tref as my inlet Temperature, how can i compare it? Thanks a lot. |
March 8, 2024, 04:54 |
Chaotic Water
Rep Power: 18 |
User guide, p. 3969 "Guidelines for Heat Transfer Coefficients"
Guidelines for Heat Transfer Coefficients This section discusses the recommendations for accurate use of the Standard Wall Functions and the built-in post-processing heat transfer coefficients. ... Heat Transfer Coefficient This option is primarily used for comparing heat transfer coefficients to experimental data or other previous work. When you use this option, note the following: ... Local Heat Transfer Coefficient When you use this option, note the following: ... Specified y+ Heat Transfer Coefficient When you use this option, note the following: ... Virtual Local Heat Transfer Coefficient When you use this option, note the following: ... |
star ccm+;field function |
Calculating local heat transfer coefficient for Cylindrical fins | karyan07 | FLUENT | 0 | April 28, 2021 23:47 |
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 21:42 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 15:35 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
