Latent heat of LH2 issue when simulating LH2 boiloff |
Taemin Jung
Rep Power: 0 ![]() |
hello!
I am trying to simulate liquid hydrogen boiloff inside a cryogenic container using StarCCM+. My ultimate goal is to find out if sloshing of the tank affects boiloff rates, but I got stuck on trying to simulate basic boiloff in a stationary tank. My problem is when I try to initialize the simulation it shows an error message saying Minimum latent heat calculated from static enthalpies of phase components at the temperature of saturation is -2.84527e+06 J/kg. Minimum latent heat is unrealisticly small in Boiling Model. Command: InitializeSolution error: Server Error I am using VOF boiling tutorial provided by SIMENS as a reference. I have inputted all the required physical values of cryogenic hydrogen such as boiling temperature, specific heat, thermal conductivity, etc. I suspect this is due to the thermodynamic properties of cryogenic hydrogen either not existing or inaccurate. Plus I may need to tweak the boiling model itself to accurately simulate LH2 boiloff, as the tutorial is based on water boiling. It would be a great help to find out what exactly I'm doing wrong, and if somebody who has experience with this kind of work shares their knowledge I would appreciate it greatly. thank you! |
I am working on the same problem, but the problem is that there is no model in straccm can be used straightforward to model a cryogenic liquid as the thermodynamic properties of gas (GH2) change significantly with pressure. I had to modify a bit the inputs gas and liquid properties through user defined properties.
boiling modeling, cryogenics, hydrogen storage |
Latent Heat Cannot be Less than zero | cvnaditya | Fluent Multiphase | 7 | March 27, 2023 10:34 |
Water latent heat? | jacek | FLUENT | 0 | September 4, 2014 08:54 |
High temperature latent heat thermal energy storage using heat pipes | Saleh1970 | CFX | 1 | August 9, 2013 05:15 |
Issue with units in heat transfer | lost.identity | Main CFD Forum | 0 | May 19, 2009 07:07 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
