Mesh interpolation
Old   January 17, 2024, 10:41
Question Mesh interpolation
Matteo Liguori
Matteo_ is on a distinguished road
Hey everyone,
I've been diving into the world of bird simulations and hit a bit of turbulence (pun intended!). Started out with your standard unsteady k-omega setup to study our feathered friend in various angles of attack. Got some cool data on pressure, velocity, and vorticity fields – all the good stuff.
Then I hit a snag. Needed to solve a special equation (check out the image attached), so I rigged up a new sim. This time I went with Finite Element solid energy, tweaked the material properties, and voila, got the derivatives I was after. Turns out you can't trick the gas domain solver into ignoring the extras we don't need, so I went the solid route.
Now for the tricky part: I've got two sets of solutions on two wildly different meshes and domain types. And I need to merge 'em. Tried to coax Star-CCM+ into doing the heavy lifting, and when that didn't pan out, I attempted exporting the data to CGNS and wrestling with it in MATLAB using cgns4m.
But no dice. So, I'm throwing this out to all you CFD gurus – got any magic tricks up your sleeves for interpolating one solution set onto another?
Any tips would be a lifesaver!
Cheers!
File Type: jpg WhatsApp Image 2024-01-17 at 14.20.44_2b811bce.jpg (10.1 KB, 6 views)
Matteo_ is offline   Reply With Quote
Old   January 18, 2024, 14:29
f-w
f-w's Avatar
f-w is on a distinguished road
Have you tried the volume data mapper? Other than the help file, here's a link to additional instructions:
https://support.sw.siemens.com/en-US...00031549_EN_US
f-w is offline   Reply With Quote
fluid domain, mesh interpolation, solid domain
flow over cylinder in openFoam saeed jamshidi OpenFOAM Pre-Processing 3 August 11, 2023 16:16
[snappyHexMesh] snappyHexMesh does not detect highly skewed faces? ptpacheco OpenFOAM Meshing & Mesh Conversion 1 January 4, 2022 13:37
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
