Question on Lagrangian phase simulation
Old   January 9, 2024, 07:32
Default Question on Lagrangian phase simulation
Stargazer is on a distinguished road
Hi experts,
I am working on the unsteady simulation of aerodynamics, coupled with Lagrangian phase (water droplets). I use clusters(hundreds of cores) for simulations, with Star ccm+12.06 R8. When the simulation goes on, there gives warning: xxx parcels reached maximum number of sub steps. The simulation becomes quite slow. I then restart the simulation on my laptop, with 12.06(no R8), there is no such warning. I run a few iterations and then upload to the clusters again, the simulation runs without such warning. I am wondering what happened in such a situation?
Stargazer is offline   Reply With Quote
Old   January 13, 2024, 08:44
Originally Posted by Stargazer View Post
Hi experts,
I think I more or less found it out. To keep a record here: the warning: xxx parcels reached maximum number of sub steps, can be solved by increase the Active Parcel Fraction Cuff-off parameter in the Lagrangian solver control, in my case change from 1E-4 to 5E-4 would work.
The R8 suffix differentiates the mixed and double precision versions. Two versions might give different track results due to different memory and accuracy on particle tracking calculations.
clusters, hpc cluster, lagrangian multiphase
A general interface question about two phasing simulation using CONVERGE tmy CONVERGE 1 November 7, 2017 16:54
Lagrangian Particle Tracking in Eulerian-Eulerian Multiphase Flow DarrenC CFX 5 April 7, 2016 15:50
Simulation of Phase change material (PCM) and nanoparticles together farah Main CFD Forum 0 November 2, 2015 15:30
a question about two phase simulation xck1986 OpenFOAM Running, Solving & CFD 0 June 16, 2011 12:00
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
