Suggestions on setting a1 of SST k-w model in unsteady simulation |
Rep Power: 6 ![]() |
I am studying the best practice on external aerodynamics of vehicles given by Siemens. In this guideline, a1=1 under steady simulation, but what about the unsteady case if I use only SST k-w instead of DES? Is a1 can be still set as 1? I realize that a1 can be tuned based upon experimental results, however what if the experimental data are unavailable, then what is the general suggestions under unsteady simulation? Thank you. |
Rep Power: 17 ![]() |
I only experimented with a1 in steady-state, but from a rational perspective, in the absence of experimental data, general suggestion would be to use the default value. Especially for a1, which significantly affects sensitivity to separation.
Results from this document (Figure 97), suggest that as well: https://www.ansys.com/content/dam/am...nsys%20CFD.pdf |
#3 | |
turbulence models, unsteady flow, vehicle aerodynamics |
Unsteady simulation of rotating duct SRF or Sliding mesh | Alisa_W | FLUENT | 7 | January 22, 2019 06:34 |
General question about SST turbulence model | Richard Renaud | CFD Freelancers | 1 | December 19, 2015 04:13 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
problem with SST k-omega model | avi031 | FLUENT | 5 | January 29, 2012 17:24 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
