Gilberto S.
Rep Power: 2 ![]() |
Hi there,
I am experiencing some issues concerning discontinuity in the MRF region. My simulation comprises a Moving Reference Frame region within an air volume region. Beneath this MRF region, there is a solid region with a constant heat source. I initiate the simulation with a heat source set to zero to initially stabilize the flow. However, upon convergence, a discontinuity arises between the MRF and the air regions (the speed profile from one doesn't match the other). I am utilizing the models, as shown in the attached image (models for the fluid region). I've already set the interfaces as mixing-plane interfaces, and the angular velocity is 2600 RPM. If anyone has insights on this matter, please lend me a hand ![]() |
#2 | |
Gilberto S.
So, what I actually found out was that the mixing plane interfaces make an "average" of the MRF effects as a whole, creating a discontinuity between the air domain and the MRF domain. I hope someone finds this information useful ![]() |
discontinuity, flow and heat transfer, mrf |
OpenFOAM MRF: Rotating - Stationary Zone Interface Discontinuity | b16328 | OpenFOAM Running, Solving & CFD | 0 | June 1, 2023 10:33 |
[snappyHexMesh] cannot find MRF cellZone | Ahyar | OpenFOAM Meshing & Mesh Conversion | 2 | November 2, 2021 02:28 |
[ANSYS Meshing] Ducted propeller MRF issue | cagriaydin | ANSYS Meshing & Geometry | 8 | January 28, 2020 09:49 |
Fan-assisted Natural Ventilation Simulation - Issues with results for an MRF case | Tellur | OpenFOAM Running, Solving & CFD | 0 | July 15, 2016 02:04 |
Particle tracking in and after MRF | andreas0209@hotmail.com | OpenFOAM Running, Solving & CFD | 1 | July 6, 2015 08:36 |
