October 3, 2023, 07:00 |
Indoor Air Flow with low velocity
Paul
Hey guys,
I'm currently simulating airflow in a simple test room. The room has a velocity inlet near the ceiling, a pressure outlet on the same wall near the floor, and a human figure in the centre (represented as a cylinder with a CO2 velocity inlet). Opposite the inlet and outlet, there's a wall section with a constant temperature, and another wall section that acts as a heated surface with a heat flux. Now onto the key physics:
Here's my problem: The simulation gives good results above a certain velocity at the velocity inlet near the ceiling. The residuals converge nicely and I am monitoring the velocity and temperature at various points in the room over iterations. I see convergence to constant values. However, when I reduce the velocity at the ceiling inlet by 50%, my solution doesn't converge and the velocity and temperature values at all observed points fluctuate significantly. With Gravity on, the velocity at the observed point fluctuates irregularly and with Gravity off, the values fluctuate regularly and the residuals do not converge either. Does anyone have any experience with this problem? Could it be related to the reduced flow rates at the inlet resulting in less forced airflow? I've tried solving this problem with both the Coupled Solver and the Boussinesq model (without CO2) at lower inlet velocities, but the same problems persist. Thanks for your help in advance |
October 4, 2023, 06:21 |
#2 | |
Chaotic Water
Rep Power: 18 |
Because except for that reason - I'd say that your model is over-complicated. As for the question itself: Maybe within that range of reduced velocities it just has unsteady unstable (in terms of flow pattern) nature? |
October 5, 2023, 10:53 |
#3 | |||
Paul
Thank you for your reply and sorry for my late response.
If gravity and e.g. the ideal gas model are used, a pressure function should be added for the pressure outlet. I have already read a lot about this here in the forum. Quote:
I am a friend of simple models, but in this case I don't know what I could simplify. Do you have a spontaneous idea? Quote:
Could I solve the problem by simulating it unsteadily, or will the solution not converge because the flow pattern is unsteady and unstable? |
October 8, 2023, 15:41 |
#4 | |||
Chaotic Water
Rep Power: 18 |
Thus it looks like it can be simplified to single-gas with small gas components as passive scalars and Boussinesq approximation instead of ideal gas should be sufficient. Quote:
That's the thing - if the flow is strongly unsteady you'll see it in the unsteady results, if it reaches some steady flow pattern .. you'll also see it %) |
Intuition for why flow follows convex surfaces | lopp | Main CFD Forum | 47 | February 1, 2022 14:14 |
Import .csv - velocity profile - error | eSKa | CFX | 9 | April 3, 2021 14:38 |
Strange axial velocity distribution in swirling flow | aravind vashista | Main CFD Forum | 0 | August 25, 2020 13:08 |
Velocity of flow v time | MitsubishiEvo6 | FLUENT | 0 | August 31, 2012 00:51 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
