Can't stop BL prisms from shrinking
Old   September 10, 2023, 20:19
Default Can't stop BL prisms from shrinking
Kailee
Kailee71 is on a distinguished road
Hi all.
I'm struggling taking a very-well-working 2D problem into 3 dimensions. With identical settings (and even with changes) I can't stop the boundary layer misbehaving at the trailing edge. Here's an image of the 2D mesh, which looks exactly as intended:
Unfortunately, when building a mesh of the identical geometry in 3D, the trialing edge loses 4 layers and becomes thinner:
I tried the obvious settings in the prism layer controls but they do not have the intended effect of thickening the prism layers to what they were in the 2D case. In fact, the 3D mesh has fewer cells on the trailing edge top-to-bottom even though the settings are identical, but if I increase the number of cells on the radius it still does not help.
Am I overlooking something obvious?
Any help very much appreciated!
Kai.
Kailee71 is offline   Reply With Quote
Old   September 20, 2023, 08:59
Lefteris
Aeronautics El. K. is on a distinguished road
I guess you could extrude the 2D mesh to create your 3D one. I believe starccm+ has the option for that but I may be wrong.
Lefteris
Aeronautics El. K. is offline   Reply With Quote
somaFoam - And plasma goes weee Destouches OpenFOAM Running, Solving & CFD 11 July 17, 2024 07:55
Add a stop criteria for an unsteady multiphase simulation Jeneas OpenFOAM Pre-Processing 0 May 18, 2018 10:22
How to stop transient simulation which has been run from scheme script? AlexanderZ FLUENT 8 August 31, 2017 05:25
command TUI / Scheme for stop and continue calculate rayolau FLUENT 1 May 13, 2013 11:20
compiling firefoam Farshad_Noravesh OpenFOAM 27 December 24, 2012 05:21
