September 4, 2023, 13:36 |
Boundary layer meshing for LES
Patricia
Hello, I am new to LES turbulence modelling. I use STARCCM+. I read on the forum that for LES y+ should be smaller than 1 to capture scales in viscous sublayer. However, while using wall functions, the y+ value can be larger. I use all y+ treatments and try to obtain values around 1. I could not find any information about the meshing boundary layer while using wall functions for LES. Should I use a prism layer to obtain y+ ~1 or just refine the mesh near the wall with even cells as I understood from this research https://iopscience.iop.org/article/1...3/1/012212/pdf
Thank you very much in advance |
les, mesh |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
[snappyHexMesh] Error defining boundary layer around cube snappyHexMesh | crizpi21 | OpenFOAM Meshing & Mesh Conversion | 5 | October 16, 2021 11:56 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 11:49 |
