Garrett Turbocharger - turbine outlet temperature |
August 28, 2023, 01:41 |
Kunisetty Vijay Babu
Can anyone explain why my turbine's temperature at the outlet (extruded) is increasing compared to the temperature at interface from which the outlet is extruded?
Boundary conditions that I've used Inlet1&2 - Stagnation inlet - Total pr - 1 bar, Total temp - 600 C Outlet - Pressure outlet - Static pr - 0 bar, static temperature - 400 C ref pressure - 1 bar, MRF for rotating domain around impeller was created, RPM - 105000 Total mesh count - 2.4M cells Results - Temperature at outlet - 523.59 C, Interface - 511.47 C, Isentropic efficiency - 56.54 % |
Impeller: temperature decreasing, should be increasing | artymk4 | OpenFOAM Running, Solving & CFD | 21 | March 10, 2024 20:15 |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 10:21 |
Temperature Data From Outlet to Inlet | shzinwoyk | Fluent UDF and Scheme Programming | 7 | October 21, 2021 10:37 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
non constant outlet temperature | amir7 | FLUENT | 0 | April 9, 2012 21:12 |
