i want to use SURFACE REPAIR in starccm+ and this error comes up
Old   August 26, 2023, 16:45
Question i want to use SURFACE REPAIR in starccm+ and this error comes up
Mohammad Mehdi Basirat Nejad
ENG_Basirat is on a distinguished road
A java.lang.NumberFormatException exception has occurred.
However, the system should continue working without further problems.
Click Show Details for the stack trace.
details:
java.lang.NumberFormatException: For input string: "۴۵"
at java.base/jdk.internal.math.FloatingDecimal.readJavaFormatSt ring(FloatingDecimal.java:2054)
at java.base/jdk.internal.math.FloatingDecimal.parseDouble(Floa tingDecimal.java:110)
at java.base/java.lang.Double.parseDouble(Double.java:651)
at java.base/java.lang.Double.valueOf(Double.java:614)
at star.meshing.ui.SurfaceRepairSettingsDialog.getBre akAngle(SurfaceRepairSettingsDialog.java:319)
at star.meshing.ui.SurfaceRepairSettingsDialog.saveCo mponentValuesToStarSettings(SurfaceRepairSettingsD ialog.java:201)
at star.meshing.ui.SurfaceRepairSettingsDialog.restor eComponentValuesFromStarSettings(SurfaceRepairSett ingsDialog.java:151)
at star.meshing.ui.SurfaceRepairSettingsDialog.<init> (SurfaceRepairSettingsDialog.java:121)
at star.meshing.ui.SurfaceMeshWidgetRepairButtons$Rep airSettingsButton.<init>(SurfaceMeshWidgetRepairBu ttons.java:1641)
at star.meshing.ui.SurfaceMeshRepairPanel.createUndoR edoPanel(SurfaceMeshRepairPanel.java:313)
at star.meshing.ui.SurfaceMeshRepairPanel.makePanel(S urfaceMeshRepairPanel.java:368)
at star.meshing.ui.SurfaceMeshRepairPanel.<init>(Surf aceMeshRepairPanel.java:144)
at star.meshing.ui.PartSurfaceMeshRepairPanel.<init>( PartSurfaceMeshRepairPanel.java:18)
at star.meshing.ui.StartPartSurfaceMeshRepairDialog$S tartRepairOperation.performAction(StartPartSurface MeshRepairDialog.java:991)
at star.coremodule.actions.RootLockOperation.lambda$e xecute$0(RootLockOperation.java:111)
at star.vis.EdtUtils.lambda$runAsync$3(EdtUtils.java: 95)
at star.coremodule.actions.scope.ActionScope.lambda$w rap$4(ActionScope.java:532)
at java.base/java.util.concurrent.CompletableFuture$AsyncSupply .run(CompletableFuture.java:1768)
at java.base/java.util.concurrent.Executors$RunnableAdapter.cal l(Executors.java:539)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.jav a:264)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.run(ScheduledThreadPoolExecutor .java:304)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1136)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:635)
[catch] at java.base/java.lang.Thread.run(Thread.java:833)
ENG_Basirat is offline   Reply With Quote
interface defining, surface repair
