Problems of simulating free decay for floating cylinder
Old   August 19, 2023, 05:42
Default Problems of simulating free decay for floating cylinder
Lixian Zhang
Lex zhang is on a distinguished road
Dear all
Thanks for reading my post. I'm a newer of Starccm. I'm now using starccm to simulate the free decay test of a floating column and compare it with the experimental results. However, the numerical results seem larger than the experimental result. As seen in the following picture, the numerical results barely decrease at 10s-25s. I'm wondering if there are some issues with my numerical models. The K-w SST model was used in the present model. I started to change the turbulent intensity and viscosity ratio to see if these parameters would affect the simulation. However, the simulation results barely changed when I changed the value of intensity and ratios. And the laminar model is also compared with the present models. The results also show a very small difference.
Are there any comments to improve my numerical models?
results.jpg`
Thanks
Kind regards
Lex zhang is offline   Reply With Quote
Solving flow past cylinder submerged near a free surface venkcy OpenFOAM Running, Solving & CFD 1 September 24, 2024 07:13
Free Floating Vertical Cylinder Arya Thomas REEF3D 3 August 31, 2022 14:14
interFoam solver for free surface flow past a circular cylinder tfuwa OpenFOAM Running, Solving & CFD 6 June 12, 2013 09:55
PLEASE HELP HELP modelling free vibration cylinder Ken FLUENT 0 June 23, 2007 12:35
CFX-5.5 simulating air free convection Dustin Lee CFX 0 April 16, 2003 03:54
