August 8, 2023, 16:34 |
Finding max value using Field Functions
Kevin
Rep Power: 3 |
Hello all,
I am currently trying to refine my mesh using AMR, and I am using field functions as criteria. One of my field functions is dependent on cell length, where cell length is the largest dimension of the cell. For instance, I have three variables, ${CellLengthAxi}, ${CellLength2D}, & ${CellLength3D}. I want to save my variable ${CellLength} as the max of the three length variables listed above. I tried writing a whole boolean statement, but it isn't working, unfortunately. Is there a way to save those three length variables in an array, and just call a max function to obtain the max and save that value as ${CellLength} . If there is an easy way to do this, let me know! Thanks in advance!! |
August 9, 2023, 04:22 |
Rep Power: 7 |
There are many ways to achieve this, for example you can nest two max functions: max(max(${CellLengthAxi}, ${CellLength2D}),${CellLength3D})
amr, field functions, star-ccm+ |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 05:49 |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 03:05 |
multiphaseEulerFoam high Courant number | Frenk_T | OpenFOAM | 5 | November 24, 2016 04:23 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL | AndoniBM | OpenFOAM Running, Solving & CFD | 2 | March 25, 2015 19:44 |
