Unsteady thermal simulation issues in star-ccm+
Old   May 22, 2023, 06:18
Default Unsteady thermal simulation issues in star-ccm+
Carl
Catho is on a distinguished road
I am not able to get a seamlessly easy simulation running. I tried field functions, *.csv file upload and some syntax but cant make any of them work. Hope somebody can enlighten me.
There is a cylindrical steel rod with 10 cm diameter and 100cm length.
At the start of this rod (position 0 cm) the following temperature profile needs to be applied:
1) Start temp 20degC
2) For 5 sec apply temperature of 200degC
3) Then increase to 300degC for 2sec
4) Then decrease back to 200degC for another 5 sec.
5) Repeat this cycle, let’s say 10times
6) Measure the resulting temp at the 20cm position and plot it against time
(below one of many examples how I approached it)
For the temperature profile I set up an excel table (Data.csv) with Column A named “Time” and then the increments (0.1 0.2 0.3 etc.) and a Column B with “Temperature” and the steps (20 200 300 200 etc.) and load that into Tools  Table  New Table  File table  Data.csv
In Region  “related surface”  physics values  static temperature  Table(time), I chose Data.csv, Table data: column 0, Table: Time (is not highlighted but showing “time”).
First the simulation did not run at all but after restart it finally did (without changing any of the above, great already).
Now, it seems the simulation runs but stops a 2), thus when it suppose to change the temperature for the first time. I don’t seem to find anything to make it keep running beyond the 20degC mark.
Can anyone help?
Catho is offline   Reply With Quote
Old   May 23, 2023, 09:55
TheIndianLel
theindianlel is on a distinguished road
Did you check the stopping criteria?
theindianlel is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Issues while simulating a 3D unsteady case IwantTobeGood SU2 2 March 22, 2021 08:01
Unsteady Turbomachinery Simulation Andrew2 Main CFD Forum 0 December 1, 2016 21:09
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
