May 11, 2023, 10:19 |
LES Index of Quality Scalar Field
Nikolaos Papafilippou
Rep Power: 7 |
Hello all,
I would like to calculate the LES Index of Quality based on Celik and for that I need the TKE from two different grids. To make a scalar field of the LES IQ I would need to import the coarser grid TKE values into the finer grid simulation. If I import them as a table that includes the whole domain and then use interpolatePositionTable(@Table("TKE_Coarse"), "TKE") the results are interpolated to the finer grid and hence the values change. How could I create a scalar field of LES IQ using the TKE from two different simulations with their proper values? |
index of quality, les |
Error in New Surface reaction model (Having multiple reactions) | surajkvs | OpenFOAM Programming & Development | 2 | May 23, 2023 21:21 |
[General] Problem with reading in multiple grouped Ensight .case files into paraview | scro1022 | ParaView | 0 | November 27, 2020 08:00 |
Division by zero exception - loop over scalarField | Pat84 | OpenFOAM Programming & Development | 6 | February 18, 2017 05:57 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[OpenFOAM] Paraview 3.98 - errors when saving geometry file | pajot | ParaView | 1 | September 28, 2013 10:45 |
