star ccm, mesh
Old   May 5, 2023, 10:58
Default star ccm, mesh
Theoharis Stavrou
Haris Stavrou is on a distinguished road
I have a simple problem here. I used the Boolean-Subtract between a model and a domain, and used a simple coarse meshing to see if everything is ok.
The result is the meshing is inside in my model and outside of it (see it in the Derive Parts figure).
The model is solid and valid.
Haris Stavrou is offline   Reply With Quote
Old   June 6, 2023, 03:23
Ankit Dave
Ankit.Dave is on a distinguished road
Would you please provide reference image and type of problem you are facing?
Ankit.Dave is offline   Reply With Quote
Old   June 6, 2023, 07:40
Lucky
When you do the boolean substract uncheck (or check) keep tool bodies as necessary. If necessary yet still, straight up delete the hanging part.
You assign the parts to be meshed, there shouldn't be any ambiguity unless you provided a part that contains an interior and exterior solid.
mesh 3d, star ccm+
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
problem when imported geometry from 3D CAD to star ccm, TAREK GANAT STAR-CCM+ 1 May 21, 2013 23:15
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
