Heating vertical liquid stream with parallel gas |
May 5, 2023, 09:57 |
Rep Power: 6 |
Hello together,
I have a problem setting up a suitable model for the following task. I want to heat a vertical free flowing liquid stream. The stream is surrounded by a parallel hot gas flow i'm interested how much is the temperature rising in the liquid from the beginning of my observation area to the end (let's say 150mm). The thing is, that I wanted to avoid models like VOF, because of the quite harsh gas flow conditions. I don't need atomization of the liquid or something like that. Only the rising temperature. In my opinion, my input parameters are mainly - lquid flow rate (and/or stream diameter) - liquid inlet temperature - gas velocity and temperature surrounding the liquid I'm quite clueless how to set up a reasonably plausible model. Does someone has an idea how to do this? And can I do this in a steady simulation? If more informations are neede, just ask. Thanks in advance Tobi |
May 8, 2023, 04:50 |
Joern Beilke
Rep Power: 20 |
Is the gas separated from the liquid by a wall or are they mixed within the "pipe"?
May 8, 2023, 08:51 |
Rep Power: 6 |
Thanks for the question.
The gas is not separated from the liquid in reality. And that's my problem. So I would like to model the direkt heat transfer from gas to liquid. Indeed, another approach could be to model a very thin pipe with nearly infinite heat transfer properties to separate the two phases. But I don't really like the idea and would test it only if I don't find any more suitable solution. BR Tobi |
May 8, 2023, 10:30 |
Joern Beilke
Rep Power: 20 |
Why don't you want to use a multiphase approach? That's what I would try at first.
May 8, 2023, 19:42 |
Chaotic Water
Rep Power: 18 |
How is the liquid stream expected to look like or behave? - Just a vertical jet going down like from a kitchen tap or a garden hose?
May 15, 2023, 09:42 |
#6 | |
Rep Power: 6 |
Also, I am always open to other approaches. BR Tobias |
May 15, 2023, 09:46 |
#7 | |
Rep Power: 6 |
BR Tobias |
May 15, 2023, 10:04 |
#8 | |
Joern Beilke
Rep Power: 20 |
There is also the Euler-Euler framework, which you can use. The gas can be just what you get from the combustion, so there is no need to model the combustion directly unless the contact with the liquid influences the combustion. www.beilke-cfd.de |
liquid heating, multiphase heat transfer, steady simulation, unsteady simulation |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 12:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
breakage of liquid stream | phsieh2005 | Main CFD Forum | 4 | October 6, 2009 21:44 |
Gas dissolution from liquid phase with CFX | Roger Young | CFX | 2 | May 6, 2008 08:37 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
