license/opening problems in batch
Old   April 17, 2023, 08:28
Default license/opening problems in batch
ElodieR is on a distinguished road
Hello everyone, first post on a forum, I hope I'll do it well !
I am currently trying to open a starCCM+ file in batch, and I tried to reproduce this method I saw on another thread (I actually modified the code because the "starccm+" command wasn't recognized by my code... and also I had to precised the path of my files, it wasn't automatically found by the computer as the member who solved the problem of the thread said...)
So I created this java file named "testCodeDoraJava.java" :
(my simulation file I try to open is "test1.sim")
// STAR-CCM+ macro: run.java
package macro;
import java.util.*;
import java.io.*;
import javax.swing.*;
import star.common.*;
import star.base.neo.*;
import star.vis.*;
import star.base.report.*;
import star.flow.*;
public class run extends StarMacro {
public void execute() {
execute0();
private void execute0() {
try {
Simulation simulation_0 =
getActiveSimulation();
simulation_0.getSimulationIterator().run();
simulation_0.saveState(simulation_0.getSessionPath ());
} catch (Exception e) {
JOptionPane.showMessageDialog(
null, e.toString()
and then, I wrote this batch code :
echo off
start C:\OPT\StarCCM2206\17.04.008\STAR-CCM+17.04.008\star\lib\win64\clang11.1vc14.2\lib\s tarccm+ -batch \\netappbsl2\JBSCengineer\ENGINEERING ORGANISATION\STRESS\485_STRESS\900_Personnel_Folde rs\Elodie Romero\batch\testCodeDoraJava.java \\netappbsl2\JBSCengineer\ENGINEERING ORGANISATION\STRESS\485_STRESS\900_Personnel_Folde rs\Elodie Romero\batch\simupourbatch\test1.sim
echo Done
pause>nul
The command window responds that there is a license problem file.
I want to precise that when I try to open the test1.sim file directly by clicking on it I have the same message on the shell of starCCM+, that's why I always need to open starCCM+ first and then load the file (with the lite license which is the only one I have at my disposal)
So maybe here is the license problem but I don't know how to reproduce this "opening by hand" manipulation with a batch code or how to solve "the double clicking opening by hand" problem...
I hope you will be able to find a solution, and at least thank's for trying !
PS : English isn't my first language, I apologize for the mistakes...
PPS : Yes, I tried chat gpt, and I still can't fix the problem
ElodieR is offline   Reply With Quote
batch, licence, opening
how to edit batch file on windows operating system breezeyu STAR-CCM+ 0 June 10, 2018 13:40
Using Batch file in combination with the workbench D0nT0m CFX 3 February 6, 2017 06:28
How to Generate Volume Mesh in Batch mode? ekraft STAR-CCM+ 1 November 3, 2016 01:59
[ICEM] ICEM CFD error when running in batch mode bgp723 ANSYS Meshing & Geometry 0 August 14, 2014 14:45
[ANSYS Meshing] Automatic mesh generation by batch file nealrm ANSYS Meshing & Geometry 5 April 1, 2014 19:59
