Harmonic Balance FE Magnetic Vector Potential Model is not simulating eddy currents
Old   February 10, 2023, 17:51
Question Harmonic Balance FE Magnetic Vector Potential Model is not simulating eddy currents
Misbah Syed
smisbahu is on a distinguished road
My current project is related to induction reheat furnaces for steel slabs. I have been facing this issue for quite a while now where the recently released Finite Element Harmonic Balance model, suited for simulating magnetic vector potential faster in ferromagnetic materials, is not generating the expected amount of heating within the steel specimen after its curie temperature is reached (the mag permeability of the slab varies with temperature via a permeability field function that interpolates over a csv magperm vs temp table).
I even ran a simulation where I set the magnetic permeability at a constant value of 1.26E-6 (effectively nothing) which completely minimizes the hysteresis heating and should solely simulate eddy current loss based heating (for example in copper). But alas this sim showed very slight temperature increase over a long period of time.
Has anyone else tested out this model and whether it simulates eddy currents in no permeability regions (non-magnetic but conductive)?
Also, if the power delivered is to remain constant, do we maintain the current(in the excitation coil around the slab) at a constant value knowing that the inductance and hence the total impedance offered by the coil changes with changing permeability of the core (slab)?
The key models I am using for the slab continua are: Harmonic Balance FE magnetic vector potential, Ohmic Heating, FE Solid Energy. Eddy current supression model is not turned on for the slab but is turned on for the coil.
Here is the paper I am following, for reference:
Nemkov et al. - 2014 - Simulation of induction heating of slabs using ELTA
https://fluxtrol.com/simulation-of-i...abs-using-ELTA
Also here is my perimeter plot for validation
smisbahu is offline   Reply With Quote
eddy current, electromagnetics, harmonic balance, induction, magnetic permeability
Starccm+ Eddy Break-Up Model Temperature Limit mertcn STAR-CCM+ 6 October 26, 2022 07:16
Inhomogeneous Discrete Population Balance Model - Load File Format kmurray234 Fluent Multiphase 1 August 1, 2022 13:29
Harmonic balance method for calculating multi-stage turbines HIT19B902072 SU2 2 April 24, 2022 02:31
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
regarding eddy break up model dj CFX 0 September 30, 2003 03:05
