How do I change fluid viscosity after crystallization reaction?
Old   February 9, 2023, 13:17
Default How do I change fluid viscosity after crystallization reaction?
OtreborPhD is on a distinguished road
Hi all, I'm trying to simulate fluid mixing in a stirred tank.
Two liquids react in a crystallization reaction, and solids precipitate. In real life, this reaction greatly influences the viscosity of the mixture and I would like to figure out how to simulate it.
Is there some way to link the mixture viscosity to the amount of solids?
Or is this already accounted for in particle-fluid interactions?
Any help much appreciated
OtreborPhD is offline   Reply With Quote
Old   February 15, 2023, 14:40
Matt
fluid23 is on a distinguished road
Do you have an equation that describes this process? You should be able to create and assign a field function to the viscosity material property.
fluid23 is offline   Reply With Quote
Old   February 15, 2023, 23:30
Bal
Bal
Bal is on a distinguished road
I have a similar question. I'm trying to simulate the precipitation of CaCO3. The rxn is as follows:
CaCl2 (aq) + 2NaHCo3 (aq) -----> CaCo3 (s) + 2NaCl (aq) + CO2 (g) + H2O (l)
Bal is offline   Reply With Quote
Old   February 16, 2023, 06:43
cwl
Chaotic Water
cwl is on a distinguished road
Yes. Yes. The question is - how much does the present solid particles affect the flow (apart from viscosity).
Then in case of "low effect" it can be modelled just by alternating the viscosity and probably simulating particles via Lagrangian approach, otherwise - full multiphase model might be needed.
cwl is offline   Reply With Quote
crystallization, mixing flow, star ccm+, viscosity model
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
