Physics and Mesh Conditions for Turbulent Internal Flow Sim |
January 25, 2023, 16:51 |
A
Rep Power: 3 |
Hi all,
My simulation is modelling the heat transfer into a pipe from outside, constant temperature condition, with fully developed fluid flowing through. Currently, I'm interested in a plain tube with nothing inside but will have to model with a twisted tape insert to promote turbulence later. I have a few questions on general setting up of the physics and mesh since I'm still pretty new to using CFD. 1. Which turbulence model is most appropriate? I see that many simulations use K-Epsilon but during research I saw that SST K-Omega is more suitable for heat transfer sims (does this still apply at high Re?). 2. Following on, which value of Y+ should I aim for? I have a general understanding of how to set up the prism layer with regards to Y+, # of layers and growth rate and that I should carry out a refinement test to properly determine independent values but I'm a bit lost on which Y+ values are suitable for a given turbulence model. 3. Any suggestions for a good way to refine mesh through small gaps (~5% of diameter)? Currently just trying volumetric controls manually All help is appreciated even if you can only point me in the right direction for one of my questions. Please just ask if you would like pictures or more info. Thank you! |
February 1, 2024, 03:03 |
Rep Power: 10 |
Hi, I think you can find what you are looking for in this review.
https://www.sciencedirect.com/scienc...5527012030386X |
heat transfer, internal flow, prism layers, turbulence models, turbulent boundary layer |
What are the best settings for a channel flow simulation? | Ashkan Kashani | CFX | 3 | October 13, 2022 21:36 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Physics and Mesh conditions missing for boundaries | MarineAiry | STAR-CCM+ | 1 | October 20, 2019 14:19 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
