Using Table Defined Inlet Velocity Appears in Isosurfaces? |
January 23, 2023, 15:01 |
Carson Ramm
I am defining an inlet velocity via the table method, and assuming star is capable of interpolating values as mesh density changes at the inlet. This aside, I am creating isosurface of the vorticity magnitude of the wake of my flow structure, and I can see a block, like in the image attached, that seems to be "sheets" of the table velocity values provided. I cannot for the life of me understand why these are showing up in a vorticity isosurface, especially since they should have a zero value of vorticity anyway. Can anyone shed some light into this issue or provide any resources that could help me understand isosurfaces? Thank you! 2023-01-23_14-57-03.jpg |
January 24, 2023, 07:34 |
mCiFlDk
Rep Power: 6 |
Hi Carson,
Could you upload the table.csv you're using and indicate, in a rough way at least, the set-up of the sim? It'd be of great help to guess what's happening here. Best. |
January 24, 2023, 10:36 |
Reply:
Carson Ramm
Hello! Thank you for your response!
Roughly, I am applying a piecewise defined inlet velocity gradient with constant velocity regions at the top and bottom of the domain and a linear shear somewhere in the middle. I am then implementing a virtual disk model along with some other models to observe how the wake changes relative to different inlet conditions. In my post processing, I create an interpolated field or my scalar quantities with 300 points of vertical resolution. The inlet velocity table is created to match this resolution. It it helps, I use a velocity inlet boundary condition for the inlet, and symmetry planes for each surrounding boundary. I generally use my inlet velocity tables in csv form, but in order to attach it to this post I have converted it to xlsx. In general, I am aiming to understand how isosurfaces work. I understand they isolate values of scalar fields corresponding to a given input. But what does say the "multiple(arbitrary)" option for them do versus creating multiple(range) with a fixed number of surfaces and a given range. And I am also hoping to understand where this "box" comes from in the image in the first post. Thank you for your time and knowledge! ShearGradTable_S_4.xlsx |
inlet velocity profile, isosurfaces, starccm+ |
Import .csv - velocity profile - error | eSKa | CFX | 9 | April 3, 2021 13:38 |
Specify both velocity and pressure at inlet boundary | NOD | STAR-CCM+ | 4 | March 7, 2021 06:36 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 11:21 |
UDF paraboloid velocity inlet | Ronak Shah | FLUENT | 0 | June 4, 2003 09:44 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
