January 13, 2023, 10:04 |
Particle setup
David
Rep Power: 6 |
Hi all I would like to model the particle dispersion of a thermal runaway battery. The idea is to create a simple model that should be able to simulate particle dispersion of various sizes (0.01-0.1, 0.1-0.45, 0.45-1, 1-1.6) in millimeters corresponding to various concentrations (the overall volume fraction should be lower than 10%). These particles are dispersed rather fast together with a gas mixture of known composition in my geometry. My goal is then to analyze how geometric changes affect the particle distribution in the geometry.... For this purpose, I aim to create a physical model that is as simple as possible with low computational cost, yet still provides realistic results.
So currently I planning to implement Lagrangian Multiphase Model with RANS using k-epsilon. Is that the appropriate approach or would you rather recommend the Discrete Element model or even the Eulerian Multiphase model? |
cfd, lagrange particle, lagrangian, multiphase flow, particle |
[General] Plotting small particle fraction profiles along depth in 3D packing | atul1018 | ParaView | 0 | September 6, 2022 08:31 |
"DDPM"; "dense gas-solid flow" Question About Particle Number in Parcel | hcs129 | FLUENT | 3 | April 22, 2022 04:53 |
DPM particle tracking "flow time step size" and " particle time step size" | monali2015m | FLUENT | 0 | February 26, 2022 16:37 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 16:30 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
