Akhil Balagopalan
Rep Power: 8 ![]() |
Hi all...
I have been simulating a ships total drag. I did it properly in a model scale ratio. But when i try with full scale model, Tke and Tdr shoots up like anything. Rest everything seems fine. Meshing seems fine...around 2m cells...Prism layer meshing and all seems fine. 10 layers i have provided. I reduced UR upto 0.1 but no use. Can anyone suggest any input in this issue. Thank you in advance. |
Marc Ricart
Rep Power: 4 ![]() |
Try open a scene and try to find where these values are and check the mesh around there. To me it looks like there is some bad mesh somewhere that creates this numerical instability
Chaotic Water
Rep Power: 18 ![]() |
Check the mesh.
Check max velocity, if it is unrealistically high - find where via Threshold derived part. |
residual |
total TKE in LES WALE SGS | nima_nz | Main CFD Forum | 16 | December 25, 2022 04:08 |
TKE & TDR in pressure inlet BC | Sisir | FLUENT | 2 | October 24, 2018 11:03 |
Tke and Tdr goes sky high? Here is a differnt view to it. | feafan | STAR-CCM+ | 3 | July 23, 2014 01:15 |
Error in flux at Fluent´s mixing plane calculation | ales | FLUENT | 0 | February 9, 2005 04:48 |
Interpreted Error in SourceTerm of k-omeca Model | Bowling | FLUENT | 0 | May 10, 2004 04:05 |
