Can I use an overset mesh region inside another overset mesh region?
Old   January 9, 2023, 09:17
Default Can I use an overset mesh region inside another overset mesh region?
michigna is on a distinguished road
"Region 1" is the environment in which the movement takes place.
"Region 2" is connected to "motion A", contains inside a rigid body with 6 degrees of freedom "Body 1" and is inside "Region 1".
"Region 3" is related to "motion B", which is defined relative to "motion A", and contains a rigid body with 6 degrees of freedom "Body 2" inside and is inside "Region 2".
Overlapping mesh interfaces are created between "Region 1" and "Region 2" and between "Region 2" and "Region 3".
In my case, this configuration does not work correctly. The calculation starts, but false information. Can such a configuration work?
Can anyone suggest an alternative?
michigna is offline   Reply With Quote
Old   January 9, 2023, 17:23
f-w
f-w's Avatar
f-w is on a distinguished road
I've only done basic (2 region) overset meshing, but I think your problem might lie in the overset hierarchy (the order in which the hole-cutting process uses regions). See bottom of help file:
HELP > Simulating Physics > Mesh Motion and Adaption > Overset Meshes > Overset Mesh Workflow > Creating Overset Interfaces
Also, I think in your case, a multi-level interface creation is needed as well (in other words, need an interface between regions 1 & 3, so that they appear in the same list in the hierarchy manager). See same help file above for details. Good luck and keep us posted.
f-w is offline   Reply With Quote
[Other] splitMeshRegions does not create interface patch between regions fsan OpenFOAM Meshing & Mesh Conversion 10 June 6, 2022 06:56
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
[snappyHexMesh] Retaining mesh inside and outside of the region occupied by .stl file pvpnrao OpenFOAM Meshing & Mesh Conversion 3 April 28, 2017 20:13
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
