Setting up heat transfer between Pipe and the Fluid within |
December 21, 2022, 21:58 |
A
Rep Power: 4 |
I'm trying to set up a simulation where a fluid flowing through a pipe is being heated from outside the pipe (heat exchanger research project). I've set it up so that the pipe is a solid with the outer wall's thermal specification set to 'Temperature' at 60C and the inner wall's thermal specification is set to 'Convection'. The thermal specification at the fluid/pipe interface is 'Conjugate Heat Transfer', energy source option is at currently at 'None' but I don't know if that is correct. Any alternate ideas on setting up the simulation for my use case are also welcome, this is just what I thought would work. Fluid and solid models are shown in the image attached, both have energy models and I've chosen steady for now, but it will be an unsteady simulation in the end. The other photo shows that while the solid is 333K as expected, the fluid isn't heating up as a result but staying a constant 300K. I'm new to CFD in general and this is my first time using it outside of tutorials so any help is much appreciated. Thank you and Happy Holidays! |
December 22, 2022, 03:39 |
Rep Power: 7 |
What you want is an interface between the two regions (solid and fluid). Then heat transfer is handled automatically by the software. When you specify "Convection" as a boundary condition on the pipe inner wall like you did, it means you must manually specify a heat transfer coefficient and ambient temperature. This would be the approach if you don't want to model the fluid flow (so a solid-only model) and instead look up an approximate HTC from literature (e.g. from Nusselt number correlations).
December 22, 2022, 20:01 |
A
Rep Power: 4 |
Hi, thank you for your reply.
In the second image, I have the Fluid/Pipe interface with the thermal specification set to 'Conjugate Heat Transfer'. Is there something I need to change with regards to this interfaces' settings? I read elsewhere that since the interface exists, setting the inner wall to 'convection' is irrelevant since the interface conditions supersede it anyway. I also tried removing the solid pipe entirely and simply specifying the thermal condition of the fluid wall to 60C but couldn't get that to work either, the fluid was just constant at room temperature throughout. I'm basically just trying to heat a fluid from the outside as it moves through a tube but can't seem to figure it out. Thank you again. |
December 23, 2022, 04:21 |
#4 | |
Rep Power: 7 |
Sorry I didn't notice you already had an interface defined.
heat exchanger model, heat transfer modelling, turbulent flow in tube |
