December 21, 2022, 09:06 |
Flip Surface Normals in Starccm+
Hello Everyone,
So I am developing Macros to run simulations on Pipes. I close the surfaces of the original Pipe Geometry using Fill Surfaces in Surface Repair & wrap the internal Fluid_Volume. Let's call these two geometries Pipe & Fluid_Volume. Then I want to create Surface Extruder Operation to extrude outlet & Inlet using the surfaces defined when closing the Pipe. There aren't enough options to properly direct this extrusion so I am using Surface normal. Now the problem is the newly created Inlet & Outlet surfaces are created with wrong direction of surface normal in some cases. Which leads to error with running Surface Extruder Operation. ERROR: orientFaces: Sidedness has an error. My Goal is to flip the surface normals for these Inlet & Outlet Faces in the Pipe. If anyone can suggest something else to effectively automate the whole operation, I'd love that too. P.S. I don't want to use the wrapped geometry for Extrusion because it creates topological errors while meshing in majority of cases. |
December 23, 2022, 12:56 |
Rep Power: 18 |
Never had this condition - only surfaces which haven't been "straight". Extrusion with direction worked.
Can you try negativ Extrusion? |
starccm, surface extruder, surface repair, surface wrapper |
[snappyHexMesh] Surface layers do not merge | mc6421 | OpenFOAM Meshing & Mesh Conversion | 3 | December 5, 2023 03:00 |
sHM doesn't add layers to any surface | Vinzmann | Mesh Generation & Pre-Processing | 0 | March 23, 2021 05:02 |
Preserved Input part during Starccm surface wrap | jalvathi | STAR-CCM+ | 0 | August 20, 2019 05:09 |
[Other] orient and/or flip face normals | hfs | OpenFOAM Meshing & Mesh Conversion | 6 | May 24, 2018 14:34 |
orient and/or flip face normals | husker | STAR-CCM+ | 3 | September 29, 2011 01:26 |
