Starccm+ Eddy Break-Up Model Temperature Limit
Old   October 24, 2022, 09:10
Default Starccm+ Eddy Break-Up Model Temperature Limit
Mertcan Kaya
mertcn is on a distinguished road
Hi everybody,
I'm simulating methanol synthesis with Eddy Break-up model in Starccm+. The reaction happens only between 220°C and 280°C. How can I give a condition in eddy break-up model that the reaction happens only between these temperature? At the moment, the larger tempeture is the higher the occurance of methanol in my simulation and it is a little bit weird
mertcn is offline   Reply With Quote
Old   October 25, 2022, 00:27
cwl
Chaotic Water
cwl is on a distinguished road
Probably - by setting up temperature-dependent reaction rate?
cwl is offline   Reply With Quote
Old   October 25, 2022, 04:28
Mertcan Kaya
I'm using of so old reaction kinetic equation from Bussche. I defined the equation as field function. But, there isn't any temperature limit in reaction rate calculation. I should define it somehow in Starccm, I think. For example, there is an option in complex chemistry model for lowest temperature for occuring reaction. I need this kind of option in eddy break-up model
Old   October 25, 2022, 04:39
cwl
Chaotic Water
(220+273.15 < ${Temperature}) && (${Temperature} < 280+273.15)
Your reaction rate
0
PS Default units for temperature are K. You can use Celcius as following: <220 C> instead of 220+273.15.
Old   October 25, 2022, 06:44
Mertcan Kaya
My reaction rate is more complex. It seems like this (see the image).
But, are you suggesting that I will put a condition for reaction with (220+273.15 < ${Temperature}) && (${Temperature} < 280+273.15)? If yes, how can I do that?
Old   October 25, 2022, 10:41
cwl
Chaotic Water
Just type your Field Function defined formula (from the image) between ? and :
Old   October 26, 2022, 07:16
Mertcan Kaya
it worked. Thank you very much
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Eddy Break Up vs Eddy Dissiaption Model HurricaneHenry CFX 1 April 22, 2011 15:40
EDDY BREAK UP MODEL (COMBUSTION) GACEM hatem Phoenics 2 December 31, 2009 16:50
