September 13, 2022, 03:59 |
Import from CAD
Marc Ricart
Rep Power: 4 |
I was used to work with closed surfaces with various names as input for CFD but now with STAR-CCM+ I see that the best way is to import solid volumes and having to split surfaces by patch in STAR-CCM+ is a bit slow and painful. I tried to import surfaces but then I had mesh problems as the surface was not fully colsed, Not sure If I have to use the surface wrapper for that or I different tesselation mode (in CAD or STAR-CCM+). Any tips? Just to be a bit more clear with that I would like: I would like to define in CAD all relevant boundaries (inlet/oulet, special faces, etc etc) and have a clean import from CAD with the relevant surfaces already split in some way. Any idea of how to achieve that (if possible) Thanks |
September 13, 2022, 14:15 |
#2 | ||||
Chaotic Water
Rep Power: 18 |
Well, except for 3D shell approach for heat transfer in thin solids. Quote:
September 14, 2022, 02:10 |
#3 | |
Marc Ricart
Rep Power: 4 |
I am using 3DX (which is what the call the latest CATIA software) |
September 30, 2022, 12:28 |
Lefteris
Rep Power: 15 |
In rhino, one can name the surfaces (boundaries) and export the geometry without joining everything into a single body. The trick, I believe, is to export the geometry in stp format.
If one then imports the stp in StarCCM+, the surfaces retain their name (and are separate surfaces). Perhaps you could try the stp format and see what happens?
Lefteris |
CAD Import Error - Never Seen Before | User_1588 | Siemens | 1 | April 24, 2018 10:03 |
Can OpenFOAM currently import CAD geometry? | Davitt | OpenFOAM Pre-Processing | 2 | November 2, 2015 07:46 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
I-DEAS CAD data import with boundary conditions | Yunus | FLUENT | 2 | March 14, 2001 14:45 |
