September 8, 2022, 16:08 |
Hull Performance - Error during Processing
maximiliano
Rep Power: 6 |
Hello to all
I have a few simulation where my vessel has a problem sinking. I use the add on of Hull Perfomance Workflof, and for any reasons taht i dont understand, the water start to enter by the deck. After several iterations, the water makes the vessel sink. I had use the add on a few times and I dont usually have problems, except with this condition. I dont know if it is a mesh issue (i dont think so because it happened with several and different cases) I attached a image from the previous moment to the fully sink. This happens when the sink and trim is not fixed. |
September 16, 2022, 14:07 |
maximiliano
Rep Power: 6 |
Does anybody have an idea of what could happen?
I tried to make a finesh mesh and decreasing the time step at the beggining of the simulation. |
September 28, 2022, 04:08 |
Lefteris
Rep Power: 16 |
Is that right that the ship doesn't have a flat side?
Have you double checked the mass of the ship?
Lefteris |
September 28, 2022, 07:23 |
#4 | |
maximiliano
Rep Power: 6 |
Hello
Thanks for answering For your first Reply Quote:
Yes, the mass is consistent with half hull displacement. Finally, I add a new image with the simulation where we can see that the wave is on the deck. Previous moment of physical time before the sink of the ship happens. |
September 30, 2022, 12:42 |
Lefteris
Rep Power: 16 |
When the ship is at rest (i.e., no movement at all) how far below the deck is the free surface?
It seems to me that it's pretty close so it would follow that the bow wave would then cover the deck. Also, with the shop at rest, could also release the sink degree of freedom and see if it floats or not.
Lefteris |
September 30, 2022, 13:11 |
maximiliano
Rep Power: 6 |
Hello Lefteris
The ship at rest is floating, I checked previously in another software. Also, draft as input, the mass is calculated on Star CCM+ and is in concordance with the previous one. Also, yes, the wave generated could be on the deck and make the vessel sink, but there is an option that clips the superstructure. |
September 30, 2022, 13:23 |
Lefteris
Rep Power: 16 |
Hi Maximiliano,
Perhaps the superstructure is irrelevant for the problem at hand but the bow bit of the hull might be rather important. Perhaps you could try keeping it and see what happens. If you really don't want the superstructure, you can split the geometry by patches and then get rid of those consisting the superstructure.
Lefteris |
October 5, 2022, 11:25 |
maximiliano
Rep Power: 6 |
The SE is irrelevant and I don't have it into account, already split it but the water over the deck is still a problem.
If you have any other idea or suggestion, I would take it and make another simulation! |
October 13, 2022, 08:13 |
#9 |
maximiliano
Rep Power: 6 |
Dear all
I found a solution, maybe is not the best, but I added more depth to the main deck so the waves donīt reach the surface. |
October 13, 2022, 09:13 |
#10 | |
Lefteris
Rep Power: 16 |
Glad you found a solution.
Lefteris |
hull, processing, sinkage, vessel |
Seeking help regarding - EHP: Estimating Hull Performance | sumon | STAR-CCM+ | 1 | September 16, 2022 14:06 |
2DOF Planning hull resistance study with overset | CFD_fan | OpenFOAM Running, Solving & CFD | 7 | July 13, 2021 06:03 |
If memory bound : how to improve performance? | aerosayan | Main CFD Forum | 13 | July 7, 2021 06:44 |
OF Multiphase: interFoam-replace DTC Hull STL file with wigley hull | zyfsoton | OpenFOAM Pre-Processing | 4 | December 1, 2020 20:17 |
DTC HULL post processing right setting | Raffaele Frontera | OpenFOAM Post-Processing | 4 | May 25, 2017 01:01 |
