Divergence when surpassing Mach 1 using simple grid (studying compressible effects)
Old   August 4, 2022, 08:45
Default Divergence when surpassing Mach 1 using simple grid (studying compressible effects)
Federico Echeverrz Vega
fede0122 is on a distinguished road
Hi Everyone!
I´m currently writing my master's thesis about the behavior of a coolant (Novec 649) when passing through a passive grid inside a rectangular tunnel (3D sim). Bit of background:
I designed 2 Domains:
The first one is 4mmx4mmx215mm, a simple square grid is placed on z=15mm, its 1.5mm thick. The grid is composed of one horizontal bar 1.5mm thick, and another vertically with the same thickness. (See photo1 & 2). I´ve established that the velocity inlet is the plane at z=0. The walls are established as symmetry planes, the cross as a wall.. and the plane a z=215mm is an outlet.
The second domain has the same attributes but now it has a full grid. The size is 50mmx25mmx215mm, the grid at z=15mm and 1.5mm thickness. (See photo2)
Ive established the boundary conditions according to the experimental data we have. Pressure, Temperature, etc.
My problem and I can´t seem to find a reason why is...
why is it that my simulation using a single cross (domain1) converges (up to Initial of V=25m/s, beyond that we reach Mach 1 and the sim diverges) and the data is validated by our experiments... but for domain 2 using the *same* initial velocity the simulation diverges.
For Domain 1 the max v_in that I can establish is 25m/s, however, for domain 2 the max that I can establish is V_in=13 m/s?
Both of those numbers produce flows that reach Mach 0.9xxxxxx ... but the moment I input 1m/s more, we breach Mach 1 and the simulation automatically diverges.
I´m using these settings:
Mesh Type: Trimmed Cells
# of Cells 30k+ for Full domain and
Space: 3D
Material: Gas -> NOVEC 649
Flow: Coupled
Equation of State: Real Gas
Real Gas Equation of State: Peng-Robinson
Time: Steady
Viscous Regime: Turbulent
Reynolds Averaged turbulence: (K-Omega or Spalart Allmaras)
For Boundary conditions I have:
Static Temperature 375K
Pressure: 281MPA
Photos 2 & 6 correspond just to a preview of the geometry of both domains
Photos 3&4 show an example of how 1m/s makes the sim Break the Mach 1 sim and thus creating divergnce
Photo 8 is domain 2 (full size) cross view of the Mesh.
Thanks a lot!
fede0122 is offline   Reply With Quote
compressible flow problem, compressible model, mach number
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
Grid Independence problem for simple pipe geometry chanchala FLUENT 13 November 20, 2003 09:24
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
momentum under-relaxation for compressible flow with SIMPLE Mihai ARGHIR Main CFD Forum 0 April 7, 2000 05:58
