July 13, 2022, 15:16 |
Rotating wheel MRF regions
Ethan gabriel campbell
Hi, I have recently been trying to set up a simulation for the rotation of a wheel. For the tyre, I am using a rotating wall. For the rim, I am looking to produce an MRF region.
When setting up the geometry I created two subtracts of the geometry Subtract 1) Rim spokes from the rotating section, producing the region of rotation. Subtract 2) Tyre and region of rotation from the fluid domain. This was going to be the stationary region. The creation of these two subtracts meant that they each shared an interface. The issue is that when meshing, there is a failure to orient a face due to self-intersections with this face being the interface within the rotating region. Does anyone know how to solve this issue ? Many thanks Ethan |
July 17, 2022, 22:05 |
#2 | |
Chaotic Water
Rep Power: 18 |
Otherwise subtracting region of rotation from the fluid domain - you get rim spokes there (since it is was subtracted from the rotating section) in the fluid domain. Anyway: right-click fluid domain and/or rotating part (in Parts) and "Repair Surface" - that would help to diagnose the issue. |
July 18, 2022, 10:53 |
#3 | |
Many thanks Ethan |
mrf, rotation, wheel |
Modeling Wheel Rotation using MRF | Lukas7117 | FLUENT | 0 | December 1, 2020 10:19 |
Modeling Wheel Rotation using MRF | Lukas7117 | Main CFD Forum | 0 | December 1, 2020 10:03 |
External flow with rotating propellors MRF domain size | MBttR | OpenFOAM Running, Solving & CFD | 2 | April 15, 2020 17:45 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
How to Create the Rotating Reference Frame of a MRF Problem in DM wrt to an Interface | Zev Xavier | FLUENT | 11 | October 14, 2014 08:46 |
