June 23, 2022, 08:30 |
Thermal Conductance
Yogesh Nalam
Rep Power: 14 |
Hello All,
I just wanted to ask if there is an option to give thermal conductance/resistance between different solid regions and if so, how do I calculate the value for two different types of materials. Thanks in advance. |
June 23, 2022, 12:18 |
Lucky
Rep Power: 66 |
If you have more than one material then you likely already have it setup as one region per each. You can create interfaces between the regions during meshing. After meshing, set the interface type to a contact interface (the default is in-place interplace). After you change it to a contact type, the contact resistance option will appear in physics values.
The value for the contact resistance you need to get from a handbook or some standard. Real values for contact resistance vary wildly depending on how the parts are assembled. |
thermal analysis, thermal conduction, thermal resistance |
Thermal Stress - Modelling of an interactive coupled Simulation | macRC | Structural Mechanics | 0 | January 10, 2019 06:14 |
air conductance in thermal model | Tommy77 | ANSYS | 0 | August 11, 2017 10:34 |
Interface Model:None or zero thermal conductance? | mak86 | CFX | 6 | October 12, 2010 23:15 |
[CFXv11]contact thermal conductance | mactech001 | CFX | 2 | August 17, 2010 19:50 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 11:18 |
