Unable to remove non-positive volume cells.
Old   May 19, 2022, 08:12
Lightbulb Unable to remove non-positive volume cells.
bitty122 is on a distinguished road
Hi all,
I am working on overset methodology for vehicle door closing.
I am facing with the following error after certain time step.
Error in metrics computation. The mesh may have non-positive volume cells.
This may be due to an invalid imported mesh or to errors initializing an interface.
Repair the mesh before proceeding.
I have performed volume correction operations; 'remove invalid cells' (face validity<0.9 and volume change <1e-3, default for rest of the functions) along with 'split by function (zero face indicator)' and 'split non-contiguous' post volume mesh generation.
On checking the solution file, I found few cells having face validity<0.6.
The option of 'removing invalid cells' along with 'split by function' and 'split non-contiguous' are disabled in the solution file.
Is there any other way to remove/resolve this.
Regards,
Bitty
bitty122 is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 14:05
[snappyHexMesh] Layers not growing at all zonda OpenFOAM Meshing & Mesh Conversion 12 June 6, 2020 12:28
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 18:16
cellZone not taking all the cells inside rahulksoni OpenFOAM 0 January 16, 2019 02:16
[blockMesh] Create internal faces as patch in blockMesh m.delta68 OpenFOAM Meshing & Mesh Conversion 14 July 12, 2018 15:43
