May 12, 2022, 09:58 |
About porosity
Rep Power: 4 |
Now there is a wall that is blocking the water flow, and I want to set the wall to be partially permeable, that is, to the porosity of the wall. I chose the wall as the same physical continuum as the fluid, and then set the wall area as the porous area. However, I found that the temperature of the water flow changed abnormally after running two steps. Could you tell me what went wrong?
Thank you! |
May 13, 2022, 11:15 |
Matt
Rep Power: 18 |
First, setting porosity will not allow fluid to pass through the wall. You will need to define resistance coefficients (inverse of permeability).
Second, in some cases, depending on your physics settings, materials and equation of state, a pressure change can cause a temperature change in the fluid. Since a porous region's primary purpose is to affect a pressure/momentum change, this could easily lead to a temperature change. The help material on porous regions has a whole section on this subject. Since you haven't given any info about what your physical models/assumptions are, it's impossible to provide a solid answer. I suggest that you review all the help material on porous regions then decide how to proceed. Edit: porosity plays a role in setting volume fractions for heat transfer and other calculations, but doesn't prescribe a pressure gradient that opposes the flow. |
May 13, 2022, 11:25 |
#3 | |
Rep Power: 4 |
Thank you very much! |
May 13, 2022, 13:36 |
Matt
Rep Power: 18 |
I think the help material is your best bet, but I will help if I can. My experience with the porous model is relegated to air filter media.
Question about porous term and porosity value in OpenFOAM | sazabi2001 | OpenFOAM Running, Solving & CFD | 12 | May 17, 2020 21:57 |
Adding porosity to UEqn.H in porousInterFoam | jameswilson620 | OpenFOAM Programming & Development | 5 | November 25, 2016 23:19 |
UDF of Variable Porosity | typhoon1010 | Fluent UDF and Scheme Programming | 3 | October 4, 2016 06:00 |
Porosity Variation with Time | Baden | Fluent UDF and Scheme Programming | 50 | July 25, 2016 07:07 |
Porosity field in Fluent | wojciech | FLUENT | 1 | September 20, 2010 12:19 |
